Hi.
Does Mikrotik not have support for configuring wireless on the wifiwave2 package? Provisions fail as we were using Device.WiFi which no longer is being reported to the ACS.
ROS: 7.11.2
Hi.
ROS: 7.11.2
Same here.
With an old device (RB951G-2HnD) Device.WiFi tree exists,
but not with a wave2 device (hap ax2).
I try with 7.11.2 and 7.6
Can Mikrotik confirm the status of tr069 and wave2 devices ?
Mikrotik responded to my support request
Thank you for contacting MikroTik Support.
Unfortunately, yes, it is a known issue. We will try to add support for WifiWave2 interfaces in future versions.
Sorry for the inconvenience.
Sigh…there always something
Managed to come right by using creating .alter files and pushing them to the routers, but it would be great to just have it work properly
We are experiencing this issue as well. Is there any hope in sight for TR069 Support for WifiWave2 devices? Capsman TR069 support would be amazing as well…
Any update on this? This is causing a lot of friction in our provisioning process.
