Wiireless WDS disconnect every minute
Hi all, right now im having a little problem interconecting two RB751U-2hnd via WDS, i have created two virtual AP, Venado and Venado Guest(invitado), the two SSID Venado are connected via wired LAN, but the Venado Guest is connected via WDS, the problem is the WDS link is disconnecting every minute or less as the log say:
10:55:44 wireless,info 02:0C:42:F8:EA:9D@Venado Guest: disconnected, received deau
th: class 2 frame received (6)
10:55:50 wireless,debug Venado Guest: 02:0C:42:F8:EA:9D attempts to associate
10:55:50 wireless,info 02:0C:42:F8:EA:9D@Venado Guest: connected, is AP, wants WDS
10:56:05 wireless,info 02:0C:42:F8:EA:9D@Venado Guest: disconnected, received deau
10:56:06 wireless,debug Venado Guest: 02:0C:42:F8:EA:9D attempts to associate
10:56:06 wireless,info 02:0C:42:F8:EA:9D@Venado Guest: connected, is AP, wants WDS
10:56:17 wireless,debug Venado Guest: 02:0C:42:F8:EA:9D attempts to associate
10:56:17 wireless,info 02:0C:42:F8:EA:9D@Venado Guest: reassociating
10:56:17 wireless,info 02:0C:42:F8:EA:9D@Venado Guest: disconnected, ok
10:56:17 wireless,info 02:0C:42:F8:EA:9D@Venado Guest: connected, is AP, wants WDS
10:57:18 wireless,debug Venado Guest: 02:0C:42:F8:EA:9D attempts to associate
10:57:18 wireless,info 02:0C:42:F8:EA:9D@Venado Guest: reassociating
10:57:18 wireless,info 02:0C:42:F8:EA:9D@Venado Guest: disconnected, ok
10:57:18 wireless,info 02:0C:42:F8:EA:9D@Venado Guest: connected, is AP, wants WDS
10:57:28 wireless,info 02:0C:42:F8:EA:9D@Venado Guest: disconnected, received deau
10:57:29 wireless,debug Venado Guest: 02:0C:42:F8:EA:9D attempts to associate
10:57:29 wireless,info 02:0C:42:F8:EA:9D@Venado Guest: connected, is AP, wants WDS
10:57:42 wireless,info 02:0C:42:F8:EA:9D@Venado Guest: disconnected, received deau
10:57:53 wireless,debug Venado Guest: 02:0C:42:F8:EA:9D attempts to associate
10:57:53 wireless,info 02:0C:42:F8:EA:9D@Venado Guest: connected, is AP, wants WDS
10:58:38 wireless,info 02:0C:42:F8:EA:9D@Venado Guest: disconnected, received deau
10:58:42 wireless,debug Venado Guest: 02:0C:42:F8:EA:9D attempts to associate
10:58:42 wireless,info 02:0C:42:F8:EA:9D@Venado Guest: connected, is AP, wants WDS
10:59:08 wireless,debug Venado Guest: 02:0C:42:F8:EA:9D attempts to associate
10:59:08 wireless,info 02:0C:42:F8:EA:9D@Venado Guest: reassociating
10:59:08 wireless,info 02:0C:42:F8:EA:9D@Venado Guest: disconnected, ok
10:59:08 wireless,info 02:0C:42:F8:EA:9D@Venado Guest: connected, is AP, wants WDS
10:59:38 wireless,info 02:0C:42:F8:EA:9D@Venado Guest: disconnected, received deau
10:59:50 wireless,debug Venado Guest: 02:0C:42:F8:EA:9D attempts to associate
10:59:50 wireless,info 02:0C:42:F8:EA:9D@Venado Guest: connected, is AP, wants WDS
11:00:01 wireless,debug Venado Guest: 02:0C:42:F8:EA:9D attempts to associate
11:00:01 wireless,info 02:0C:42:F8:EA:9D@Venado Guest: reassociating
11:00:01 wireless,info 02:0C:42:F8:EA:9D@Venado Guest: disconnected, ok
11:00:01 wireless,info 02:0C:42:F8:EA:9D@Venado Guest: connected, is AP, wants WDS
11:00:18 wireless,info 02:0C:42:F8:EA:9D@Venado Guest: disconnected, received deau
11:00:23 wireless,debug Venado Guest: 02:0C:42:F8:EA:9D attempts to associate
11:00:23 wireless,info 02:0C:42:F8:EA:9D@Venado Guest: connected, is AP, wants WDS
11:00:37 wireless,debug Venado Guest: 02:0C:42:F8:EA:9D attempts to associate
11:00:37 wireless,info 02:0C:42:F8:EA:9D@Venado Guest: reassociating
11:00:37 wireless,info 02:0C:42:F8:EA:9D@Venado Guest: disconnected, ok
11:00:37 wireless,info 02:0C:42:F8:EA:9D@Venado Guest: connected, is AP, wants WDS
I configured an static WDS with an 1450 MTU, and a Mesh interface with the same MTU, correct me if this is wrong.
/interface wireless
set 0 band=2ghz-b/g/n channel-width=20/40mhz-ht-above disabled=no distance=\
    indoors frequency=2437 hide-ssid=yes ht-guard-interval=long ht-rxchains=0,1 \
    ht-txchains=0,1 l2mtu=2290 mode=ap-bridge mtu=1480 name=Mikrotik \
    preamble-mode=long rate-selection=legacy ssid=MikroTik wireless-protocol=\
    any
/interface wireless
    any
i have put the WDS and the clients on the access list but no success in this problem. :frowning:
If anyone have any solution is welcome :slight_smile:.
Thanks Everybody
