Hi i would like to know if anyone her tried the wiki eoip example and succeed? im tryin to make an eoip bridge with main ap and share the internet over it. Have been struggling with the example on wiki but could not managed to have it worked; also have problems with bridge! it seems forwarding on client side at wiki; but all i see is the designated port message! ![]()
You can use this example,
http://www.mikrotik.com/testdocs/ros/3.0/vpn/eoip_content.php#.3
Make sure MAC-Addresses are not the same on both sides of EoIP tunnel for the EoIP interface.
so far so good! managed to get the eoipbridge running, clients can get the ip addresses va dhcp from the main router, added nat but can get the internet working! any ideas for reason ?!
done! have it worked!
Hi! Please can you help me? Iām stuck.
Situation:
2 RouterOS boxes, different ISP, connect through Internet working
Local router: 2 real interfaces -1st to ISP, 2nd to LAN; 1 virt interface EOIP
Remote router: 1 real interface to LAN&ISP via LAN router; 1 virt interface EOIP
I have now EIOP working fine, I can ping the IP address I added to this interface.
I want to set things up the way I route all internet traffic through Remote router.
Now what should I do next?
Thank you
Venoush
