wiki User Manager
In this site http://wiki.mikrotik.com/wiki/User_Manager/QA/How_to_make_HotSpot_and_User_Manager_on_the_same_router
thay assume the ip address of router the userman. is 127.0.0.1 and so forth …
is that mean i have to use this IP ?
i used with out any reasult !!
plz some body explain more in detail .. thanks
BEST REGARDS
NO..
I is just pointing the radius server to the “local resource”..
Also it is telling the radius service that the “local host” will be using “its” service…
In short it is just pointing everyone back to the same point…
If you want to run more than one router off the UserManager service then use the appropriate IPs for the host / client settings.
Craig
