Will backup work on another device?
my RB1100AHx4 was defective and i got a refund from the reseller.
I have a backfile from my setting but no clear export from all my settings.
Over time my setting get more complexive and i also had some scripts.
Is it possible to import this backup file directly on a Mikrotik CCR1016-12G router?
Is there any other way to get a clear printout from the firewall rules a.s.o. to reenter the commands in my upcoming device?
Thank you,
faxxe
No, backup files are completely incompatible between different device models. They are partially compatible with different devices of exactly same model (but care needs to be taken).
Binary backups are intended to be restored on the very same device which was backuped earlier.
export compact
Sent from my SM-A705FN using Tapatalk
I dont have the device anymore. Was defective and the reseller keep it in his shop.
Maybe Mikrotik can “convert” my backup file?
-faxxe
