Will Huawei E3372 work on Hex(rb750gr3) usb port, anyone tried?
I bought hex so now im considering going on LTE, and adding lte in bridge is still not avalaible??? Share some info, thanks.
Regards
LeRadelle
Yes, it does work on G3
But you may not select the “lte” interface into the bridge.
By the way may I ask, why do you need to make the bridge?
Sent from my SM-N920T using Tapatalk
Good question, how will i share LTE internet connection on ethernet ports that have connected sxt2? Im new to the rb so any network suggestion would be good?
Sent from my iPhone using Tapatalk
Why not just put lte as wan interface? Remember to put dhcp-client to lte interface.
Hi;
I have bought the hEX(rb750r3) and E3372(hiLink version) so im having trouble making it work i have put a dhcp client on lte interface, there is so many posts saying that E3372 needs to be used as serial modem by changing firmware, is there a way to use it as a hiLink version and what are the disadvantages of it? Just to add more info im using hEX as central point of my network i have two SXT units connected to it and distributing wifi over my house, since wired internet is slow(5Mbits) i whant to go via 4G using E3372.
Regards
LeRadelle
