Will MetaRouter be supported on the RB600/1000 any time soon
I’d really like the answer to be yes on this one!
Looking at the specsheet for this device, it is ideal for our needs, with one crucial missing piece : H323 Gatekeeper.
I was thinking that we could run a virtual session for this one system, and run the rest from RouterOS on the one board, but this is only possible AFAIK with the RB400 series, and these only have support for MicroSD which is unsuited to cacheing.
If the PPC-based Routerboards had access to virtualisation they would be a perfect match for our requirements.
Yes, the answer is yes. MetaROUTER should be supported in the next 4.0beta version for the RB1000.
how likely is it going to be supported on the RB600 ?
When I bought the RB600 I had assumed it to be part of a “higher end” range and reasonable future proof.
However I get slowly the feeling that it was a “dead” product which is a bit disappointing.
Long story short, I’m wondering to just throw it away and get something else or to keep it.
One of the features I’m badly missing is the MetaRouter because it would enable a full featured DNS, DHCP, and OpenVPN setup.
Have a nice day,
Andre
