Will my r5h card overheat when running turbo
Hi all. I have two r5h cards. The problem is that im only getting good signal when im running it in 5ghz-10mhz. Im worried that the life of the card will be shrten when running it in that mode. Can someone maybe shine some light.thanx
why should it? It’s designed to do these things :slight_smile:
someone who have his own wisp has told me that runnng turbo shortens the cards life? What does the 5ghz -5hz mean and the 5ghz - 10mhz? Thanx
no, that is not true. the card is made for this reason, so it works just as in other modes.
thank you im going to leave it in 5ghz-10mhz mode. that is when i get the best results
probably you see less noise in narrow channels thats why it works better in your situation.
