Will not reboot
When I issue a system reboot command, the system will respond with what looks like the correct message, but it never reboots…it just sits there. I was using the Crucial 128 Meg compact flash and switched over to a San Disk 64 Meg flash thinking it was the corruption problem that I heard about last week, but it still does not reboot.
It hangs at “Restarting system.” and never comes back up until I cycle the power on the rascal.
I’ve even upgraded to version 2.9.18 and still the problem is there.
I’m using the standard Wrap board with 2 Ethernet interfaces.
Any ideas?
Kelly
kaver68,
Do you have ‘routerboard’ package installed ?
Nope.
Kelly
Install ‘routerboard’ package, than reboot command has to work properly.
That did the trick!
Thanks for being around so late at night!
Kelly
it’s 10AM his time :slight_smile: no night here
:smiley:
