I want to swap out a 450g that is doing dhcp for 75 accounts
If set up the same way, will the new one hand out the same addresses to
the accounts on line?
thanks
thanks
It will if you make the leases static
thanks for the response
yes in the original router all addresses were marked as static
I will try the switch tonight
thanks again
in Ottawa
I did try and it was not handing out the same ones and soon had a customer calling and I was
seeing ip conflicts.
Any ideas: should the router be disconnected for five or ten minutes perhaps?
Just copy over DHCP lease records and you’ll get the same addresses.
from the old one run:
/ip dhcp-server lease export
Then simply paste the output into the new one.
thank you both, I will try again after there is not much traffic
thank you
I tried in terminal (don’t see export in winbox)
I copy the screen but when I transfer to new router I get “input does not match value of server”
not sure what part to copy
[admin@MikroTik] >
[admin@MikroTik] > /ip dhcp-server lease
[admin@MikroTik] /ip dhcp-server lease> add address=10.5.50.239 always-broadcast
=yes client-id=1:0:15:6d:ee:a9:c3 comment=“” disabled=no
... mac-address=00:15:6D:EE:A9:C3 server=server1
input does not match any value of server
[admin@MikroTik] /ip dhcp-server lease> add address=10.5.50.220 always-broadcast
=yes client-id=1:0:15:6d:d0:95:75 comment=“” disabled=no
... mac-address=00:15:6D:D0:95:75 server=server1
goes on for the whole list
got it with everyone’s help
the name of the server was not the same in both routers
changed name to match and all is good
thanks again
