Hey all, Getting a Rb532, one Xr9 One Xr2, and a CM9 Will they fit in this unit??? I don’t want to buy that routerboard if they do not fit… Also will there be any problems with all 3 Cards in one routerboard… (power issues) (heat issues) (grounding issues)?? thanks -Jordan
532 only has two slots…
Quick and to the point.
However, he could get an expansion adapter.
Crap i forgot about that… Im an idiot excuse me…
Let me change this up… With a Daughterboard will the cards work fine etc etc?? -Jordan
Should be fine. Just make sure you use a good power supply.
24volt 1-3 A ? I think that would do it…
24 volt power supply will blow up a RB532, unless you have it on the 48V setting. Don’t use more than 22 VDC on the low voltage setting.
24 volt will work fine. Especially if you have a long cable run.
Hooked it up last night actually, works fine, didnt see much difference in performance but atleast it has the power if it needs it. -Jordan
