Hi, just as the subject says i am wondering if there will be any updated models for all the current hardware that supports the passive poe to support “active” poe or 802.3-at/af?
This would increase the range of the products and the simplicity to set them up, just pnp and it will start.
I would love to see the current small hex and hap devices to have af/at compatibility rather than just passive poe and the need of injectors.
They would also be able to be powered by the more lower-cost/end devices from netgear, tplink, dlink and so on for those that doesn’t want to buy the bigger switches from mikrotik just
to have passive poe options.
i wouldn’t mind if both passive and at/af was supported.
a pigtail version of RBGPOE-CON-HP would be a nice addition as well i think with a barrel jack output for the power and just data from the rj45 out, like the RBGPOE.
