I can access fine my IKE2 server from iOS, but, I just can not get it working from win10.
The error message on the routerboard’s log is : identity not found for peer: DER DN: CN=zxs@***.ddns.net,C=HU,ST=,L=,O=,OU=,SN=
On the win10 client it says that IKE authentication credentials are unacceptable.
I did tried to google for solution and here also. The strange thing is, I am able to connect from an older win10 install (updated to same build version).
The authentication method is digital signature.
Thanks,
JG
I kept searching and found another thread, where it was suggested by sindy to "So double-check that you have my-id in the identity row set to auto. ". In my setup it was on auto, but I just did tried to set the remote ID type to auto and it works. I think I understand what it is, but not 100%.
So, it works now.
JG
