WinBox 3.0beta2 router selection and login
Can you restore setting when double-click on router list moves to password textbox rather than auto connect? :wink:
Thanks!
On double click is better as work now,
for copy just one click…
Just installed winbox 3. When I launch it, it eats up one entire CPU until I quit it. It does what I ask it to, but my fans rev all the way up and it acts like it’s mining bitcoins in the background. I’m running it on a Mac under Parallels, as I have always run winbox.
Use one true computer and you see no 100% cpu…
Not an option, unless you’re buying.
The previous Winbox did not do this. No other Windows program under Parallels does this.
But what if you don’t have saved passwords? :>
It’s not better in this case…
Maybe:
if password is saved: doubleclick = logon
else doubleclick goes to password box?
not, because password can be empty
Can’t find any changelog. I installed it and cannot see any differences. What are the differences from previous version? Just bugfixes?
Where you download that?
Please continue this on official winbox 3 topic!
Aaargh. I thought this WAS the official Winbox 3 topic. :frowning:
rextended, please consider that some people don’t save passwords:
if I double click on a router with no passwod saved winbox3 goes with login procedure anyway - which always and with ERROR: wrong username or password
Can you tell me what is the point of that behavior? :>
In Winbox2 we have very useful and extremely fast path:
double click > focus to password box > enter password > hit enter > you’re in
(only two mouse clicks at all)
In Winbox3 the procedure’s logic is broken:
double click > ERROR: wrong username or password
ps. Where’s the official topic? :wink:)
I found it here:
http://forum.mikrotik.com/t/winbox-3-beta/79126/41
