strods
January 23, 2017, 2:07pm
1
What’s new in v3.10:
*) fixed crash on latest Windows developer builds;
*) fixed crash on disconnect;
If you experience version related issues, then please report them to support@mikrotik.com .
Winbox is available here:
http://www.mikrotik.com/download
If you try to upgrade directly from Winbox loader and version is not available, then you might need to wait for a while until cache in path between your device and our servers is refreshed.
Is this version of winbox fixes “has stopped working” message at windows 10 insider preview build 15014 ?
raffav
January 23, 2017, 2:38pm
3
Yes
Just try yourself
Enviado de meu XT1580 usando Tapatalk
Many thanks for you, I will upgrade to the new build.
radpi
January 23, 2017, 3:50pm
5
I can confirm this build of winbox works with windows 10 build 15014
w0lt
January 23, 2017, 4:33pm
6
So Far..So Good.. Works correctly using "MacOSX Crossover !!
-tp
UAU, four releases in 10 days!!!
No “disconnect/close”-issue on MacOS with wine-1.9.23 or wine-2.0-rc6
Good work!
Still crashing.
Windows 10 Insider Preview Build 15014.
When I click check for update of winbox then message show “There are no new versions”, My current winbox version is 3.9
you can download it from webpage directly. Check-for-update delays are usually down to proxies (cloud) - ether yours or ones that MikroTIk uses for version discribution.
strods
January 24, 2017, 2:34pm
13
MostafaAta - If Winbox is crashing it does not necessary mean that this is the same problem. Please try to reproduce crash and then send supout file from router to which you were connected to support@mikrotik.com
I had upgrade to Windows 10 Insider Preview build 15014 now and Winbox 3.10 is working good.
thanks.
w0lt
January 24, 2017, 4:47pm
15
WinBox 10 has been working great for me..Kudos to the MikroTik Team that worked on it.
Future request: Please preserve the state of the “Torch” collect blocks when exiting Winbox so I don’t have to keep reselecting them each time?
Thanks !!
-tp
Drag and drop is not working! (for upload files)
conrad
January 24, 2017, 6:15pm
18
I will ask once again…
This problem can be solved?
It seems it was promised in version 3.0
null31
January 24, 2017, 6:31pm
19
Also, was solved the problem after close the winbox, which left a dead process running on the Arch Linux using wine 2.0rc6-1 or wine 2.0rc5-1.
Greak work!!
WInbox 3.10 running perfect without appcrash notice again. thank u team,
