*) fixed wireless interface tabs, HT MCS tab was not shown in 5g/n/ac mode;
*) ask for confirmation when exiting or disconnecting in Safe Mode;
*) fixed problem where context menu Add command could not be selected if it had submenu;
*) fixed problem where ip accounting settings were allways disabled;
If you experience version related issues, then please report them to support@mikrotik.com.
If you try to upgrade directly from Winbox loader and version is not available, then you might need to wait for a while until cache in path between your device and our servers is refreshed.
raffav - This is due to cache between upgrade server and your computer;
juliokato - We can not reproduce such issue and seems that others does not have it too;
baragoon - This is not supported for ac wireless cards.
I don’t seem to be able to launch winbox 3.11 with any comparability setting or none of them? Anyone having that issue?
Windows 10 Enterprise 64bit 14393.693
NOTE: i had the same issue with 3.9 but was quickly replaced with 3.10.
" ERROR: RoMON Agent not found. Add it to Managed List." Locks out Winbox ! Deleting the MicroTik folder in %appdata% used to fix it. Not now.
Locked out of the entire network on my primary Windoze PC.Adding valid agents does not help.
Also not clear about the Master Password on the Romon Menu. Perhaps that just locks down
Romon for this session/PC? Is this documented anywhere?
