Messy layout on windows classic theme ( https://s24.postimg.org/pf9wqfapx/winboxerror.png )
Crap misspelling in pci device (if you go to system > resources > pci and then click on any device you will see catagory instead of category)
Crashes on disconnect for windows 8.1
Loads of issues with HAP lite (cannot disable services for one) too many to even bother.
Yes, I confirm this bug of 3.8 at RB3011:
CAPsMAN → Access List
Two buttons at header panel for quick enabling/disabling access entry do not work. Nothing happens clicking at them.
Of course, I still can change enabling some entry opening it and using inner button disable/enable.
Have anyone faced with bridge flood in wireless and vlan interfaces when traffic have to go to ethernet interface with this 6.38 version?
P.S.: Sorry for wrong topic, noticed to late..
HI - in winbox 3.8 I am unable to set ports in firewall rules (the src port dst port and any port) are greyed out.
In winbox 3.7 it works (the fields are editable).
