Winbox 3 for Ros 7.25
For those whose eyes start bleeding when using version 4 (myself included), AI has created a version 3 compatible with 7.25. While not all settings may be available, the core features—including Cyrillic support—work just fine. It’s a real SHAME that the company is forcing users to adopt the new version, leaving them no choice; in this era of LLMs, maintaining version 3 would have required virtually no effort on their part.
winbox64.zip (893.4 KB)
Could you share some details on how it was created and what AI tools were used?
And thank you so much :heart:
Who knew that we'd have one so soon.
Altough people won't trust it because they don't know what you've baked in the file.
But here we are :upside_down_face:
you always can use https://www.virustotal.com/ - its free
hermes + rea mcp
Out of curiosity, i did a virus total scan, looks clean /shrug
https://www.virustotal.com/gui/file/9421ce884ffc820e8d9906d7ca3f2b2774df993a242d100940e810d2e0c73490/detection
I tried it. But it crashes after hitting the "Connect" button.
strange, win11 - works just fine, maybe some one else will try?
For me connects without issues
And with 7.26 too. However, I don't have CMR-compatible routers to check, if this new feature would work.
I am running 7.26beta3 with cmr package enabled. When connecting it also triggers a autosupout.rif....
2026-10-27 16:16:27 system,error,critical Automatic supout.rif file generated due to service malfunction, please contact MikroTik support and supply the generated file
I am sorry to say, but I am one click away from giving a downvote. The reason: I am willing to try this potentially harmful WB3 version by AI. But it is my own decision because I know the consequences and I only use a restricted user. And I mean harmful not from a "omg virus/malware" perspective, rather as "omg! it can f**k up your device configuration or cause instability".
EPIC DAY
@Masyanich
Огромное спасибо от всего сердца!
Grazie...
As far as I understand, it was created for 7.25 without cmr in mind, so may be it triggers a crash... Have you checked with 7.25?
Currently no device on 7.25 unfortunately.
7.26beta3 on hAP be3 and it crashes as soon as connect button is pressed. hAP ax S on 7.24.2 works without a problem on both IP and MAC.
EDIT: hAP ax S on 7.25 works on both IP and MAC.
EDIT2: 7.26beta3 also works on hAP ax S on both IP and MAC.
tnanks for testing! all my devices is 7.25 including standant packages + dude on one device, and it works for me, i think crash depends of some new packages, but not sure
I think CMR is the problem here because on hAP be3 there is CMR server running, and on hAP ax S it's disabled.
EDIT: Yea, it's CMR, as soon as cmr package is installed Winbox3 crashes.
oooookkkkk, i will try to install cmr to chr test router and make a new version (with stub maybe?) that will no crash, i just need some free time
Thank you so much for sharing this! :folded_hands: May God bless you and grant you good health! Really appreciate your help!
Connecting to routers using the 'cmr' package works; however, please note that selecting an item cmr from the menu will cause a crash of winbox application—this part has not been adapted yet; for now, only the connection functionality has been restored.
winbox-cmr.zip (893.3 KB)
