So I have a weird issue, using Windows 8.1 Update + Winbox 3 RC9, some menu items are missing from my Winbox. It is extremely frustrating because it forces me to do everything via command line. Of course the solution would be to simply upgrade these routers but getting downtime to do so is not easy, hence why they are still on v5.
I have the same problem.
We have numerous systems running ROS5 and its very frustrating to use two different versions of winbox.
Will mikrotik fix this?
