WinBox 4.0beta30 on MacOS 26 Tahoe issue
It used to work like a charm, but recently WinBox seems to not see a network. I believe the issue appeared after macOS upgrade to macOS 26 Tahoe.
Meanwhile, WinBox is not listed in the Security & Privacy in the Local Network section. So I cannot provide an access explicitly.
The host as it is accessible from the browser with no issues.
When i comes to this problems, I always delete the settings from the app.
Sadly I don't know where WinBox hide's it's settings on the MacOS version.
On my Arch Linux Install, when I start Winbox from the command line I get some hints where it stores the settings.
[patrik@archlinux mikrotik]$ ./WinBox
APP,INFO: version: "4.0beta30"
APP,INFO: loading addrs db from: "/home/patrik/.local/share/MikroTik/WinBox/Addresses.cdb"
APP,INFO: loading ok
APP,UPDATE: version fetched: "4.0beta30"
APP,UPDATE: nothing to update
APP,INFO: app about to quit
PERS,INFO: saving data to "/home/patrik/.local/share/MikroTik/WinBox/settings.cfg.viw2"
Maybe you can do the same from terminal, to get the info.
open -n ./WinBox.app
Does not helps unfortunately
smotrov@MacBook-Pro /Applications % cd ~/Library/Application\ Support/MikroTik
smotrov@MacBook-Pro MikroTik % ls -la
total 0
drwxr-xr-x@   3 smotrov  staff    96 Sep 24 20:20 .
drwx------+ 146 smotrov  staff  4672 Sep 24 20:20 ..
drwxr-xr-x@   3 smotrov  staff    96 Sep 24 20:20 WinBox
smotrov@MacBook-Pro MikroTik % rm -rf WinBox
Same symptoms.
I just updated to Tahoe and I have the same problem.
The user data is in “/Users/{username}/.wine/drive_c/users/{username}/AppData/Roaming/Mikrotik”
Unfortunately deleting it did not resolve the issue for me.
  1. close all instances of Winbox
  2. copy the Winbox 4 App to /Applications if not done already
  3. in the Applications directory, rename Winbox to something else, e.g. Winbox → Winbox4
  4. start Winbox4
  5. the Grant access to local networks popup should appear
  6. click ok
  7. done
To enaable
To enable after latest MacOS update WinBox to see a network, you have to do as follows:
Go to Settings–>Network–>Firewall–>Options–>Block all incoming connections (turn it off)–>WinBox.app (Allow incoming connections)
