WinBox 4.1 configure firewall for a basic LAN whit 4 PCs
Hello, I using WinBox for configuring the firewall. How can I deny the LAN computer’s to see each other?
For example:
et02 PC1 with IP: 192.168.5.247
et03 PC3 with IP: 192.168.5.250
Router IP: 192.168.5.1
Please reply meee!!!
You would need to enable the IP filter on the LAN Bridge.
Then you should be able to filter between the two device’s IP addresses.
If you don’t want to use the IP address, you would take the two interfaces out of the bridge, and assign them each a separate subnet, then you can filter based on subnet, or even interface.
But in firewall rules dont i have to set anything??
For example accept or drop IP’s
Van you give me an example ?Please :slight_smile:))))
