WinBox 4.4 released!
Indeed. I can't name an app which has "check for updates" functionality without a setting to turn it off. It always come together. But then there is Winning Box 4 :upside_down_face:
I've tried to replicate this. I've set a reject rule for that domain, nothing weird is going on.
No notification of update, no error, can login without a problem.
He probably does more than just a reject firewall rule.
Some crappy hijacking to show a scary message. :upside_down_face:
He most likely forbid WinBox to open any socket connections, but it obviously needs it, not for update check but to... connect to router :>
Well, that escalated quickly...
I think it is pretty obvious desktop firewall or similar on the OPs machine causes "permission denied" return when Winbox tries to open a socket using Winsock API for update check.
Redirecting it to 127.0.0.1 (localhost) is not blocked and Winbox can open a socket.
Winbox seems to tolerate not getting a response from an open socket, but stumbles if not being able to open a socket at all and blocks the UI thread. Which was reported before and should be fixed. Period.
And yet the usual pack of gatekeepers lines up to attack someone just because he reported a real issue with wrong diagnosis.
No, he refused to look into the issue.
I have suggested to look at the stdout of winbox to see more infos:
But he refused to do:
I alread had the idea of some firewall/avv denied the socket:
but the response was:
But he favored the idea of the "evil winbox developer" instead.
It was said numerous times: report a bug. e.g. WinBox 4.4 released! - #180 by Znevna
So refrain from calling someone here a "gatekeeper". The only gatekeeper was @sciensys himself. He came here to troll us.
WinBox update check and connection to the RouterOS are independent and async tasks. Nothing is specially blocked by WinBox. The "permission denied" seems to come from Operating System, which could be caused by firewall or some other security feature.
I can confirm that. This is what is happening in my isolated network. It logs the message, does a couple of retries, then gives up and continues without the "recent version check".
I have never seen that "permission denied" error on that network. When it happened to me I would likely use strace to find out what system call is returning a result like that.
Good :slightly_smiling_face:, though, as said earlier, it is IMHO not user friendly (and not "smart") to do this check when the tool is launched (before the user has an option to enable or disable this feature).
I agree, the version check should be a configurable setting in WinBox.
But hey, I think that QuickSet should be a removable feature as well. And it probably is more dangerous.
WinBox version 4.5 has been released:
Did a bit of testing when patching primary server (carries my DNS):slight_smile:
  • DNS (server) down fully (no resolvers available): WB4.4 instant start, instant connect - no messages.
  • Internet link down on RB5009, but DNS server running (local resolution, nothing external): WB4.4 instant start, instant connect - no messages.
The only thing noted in either of these cases was that available updates were not displayed, nothing else.
I didn't spend a lot of time, but the obvious stuff won't break it.
I confirm.
I just redownloaded the latest version 4.5 and the problem went away.
Now WinBox 4.5 first connects and downloads the router settings and only then makes requests to 159.148.147.251 TCP443
Packets are dropped, but WinBox continues to function normally.
Thanks everyone.
Now the tape is off
All the other new features are very convenient and flexible, but they take a little getting used to.
