WinBox 4.5rc released!
What's new in 4.5rc2 (2026-10-29):
  • table: show tools in toolbar as buttons if there is space available;
  • table: compact enable/disable/remove/comment buttons when there is no space;
WinBox files for Windows, Linux and macOS are available here:
https://download.mikrotik.com/routeros/winbox/4.5rc2/WinBox_Windows_arm64.zip
https://download.mikrotik.com/routeros/winbox/4.5rc2/WinBox_Windows.zip
https://download.mikrotik.com/routeros/winbox/4.5rc2/WinBox_Linux.zip
https://download.mikrotik.com/routeros/winbox/4.5rc2/WinBox.dmg
What's new in 4.5rc1 (2026-10-27):
  • ui: rewrite combobox to support filtering/suggestions;
  • app: ignore QML_DISABLE_DISK_CACHE env variable in case user has set it somehow;
  • routeros-api: add support for new ui types;
  • table: optimize large ordered list rendering (e.g. Log);
  • table: optimize fields where data are retrieved from other table (e.g. DHCP Leases -> Bridge Port);
  • ui: add topology support;
  • ui: change text selection color in dark mode;
  • ui: make input field and table cell text color brighter in dark mode;
  • ui: rework bar graphs ui;
  • ui: update and add new icons;
  • ui: update icons for users tables;
https://download.mikrotik.com/routeros/winbox/4.5rc1/WinBox_Windows_arm64.zip
https://download.mikrotik.com/routeros/winbox/4.5rc1/WinBox_Windows.zip
https://download.mikrotik.com/routeros/winbox/4.5rc1/WinBox_Linux.zip
https://download.mikrotik.com/routeros/winbox/4.5rc1/WinBox.dmg
Finally icons for CMR menus and "app" menu as well. I also like the subtle updates of icons e.g. undo/redo icons. Also dark theme got some little update. Thanks!
Neat, CMR dashboard new UI element:
4.4
4.5
Good job! The 4.4 version was kind of useless. Stupid horizontal bars with no possibility to read actual numbers. But now in 4.5 this is really nice.
Nice, but PLEASE get rid of this Tools menu:
and make all the Actions immediately visible/selectable.
Thank you!
When there is enough space in the toolbar there should not be a tools menu at all. To always show the tools menu is just adding a useless click.
There is a bug with the calculation of the "auto-size column by double-click" feature for the fields with the percent bar:
auto-column-width-bug
And it's also buggy (overlap previous column) if we resize manually.
This is also a minor bug that was already present in previous versions: The Alt+F search feature currently also searches the hidden "HTML" formatting (of the blue text). We can see them if the search term has the letter f standing alone:
Same when we type <space>font:
What I like about the current menu bars is the consistency of Enable, Disable, Remove and Comment across all relevant windows. I am OK with the Tool menu and the choice to have it open down the right hand side, but I understand what you are getting at.
What might alleviate this is to make the Tools item a hotspot, such that the menu opens on hover.
Some don't like the wasted space of the sidebar actions menu. But then the alternative is a toggle-menu. It is not only the extra click, I like to see "available tools" on a first glance. Otherwise we could hide all UI by default and place "reveal now" buttons everywhere.
This would be the worst of all! This is not some fancy gaming app intended for kids that should look "good". This is a business app for people doing business stuff (even when playing with it at home) and there should be as few gimmicks as possible.
The key word is "efficiency". Do as much as possible with least amount of moving the mouse and clicking through unnecessary menus and searching for obvious things.
Just my ¢2...
Please yourself. I seem to remember Windows 3.0 being derided as a gimmick and not suitable for business. My suggestion is not intended to make WB kid friendly or cool. It is a serious suggestion using features which are likely available in the development tool kit
Yes, the suggestion removes a tool click. Obviously you don't have to like it or agree, but as you don't like the present offering, perhaps you could still give it credence as a serious suggestion.
Does this allow for any injection maybe?
But one still has to know where is that "Check for update" option hidden, hit the "hot spot", then be careful not to move the pointer outside menu area because it would close and hide the wanted option... I have seen that too many times on badly coded websites and apps.
The point is to make everything immediately visible and always in the same place (good old DOS days in the 90s when I could guide my customers to do anything with only a phone call and without seeing their monitor. Try to do that now with same apps looking totally different on two "same" devices, even worse when things appear and hide because I only moved my mouse).
Routeros auto upgrade for routers that don't have direct internet, please
I did a side-by-side comparison of 4.4 and 4.5 RC1.
It seems that all text that was previously "dimmed white" is now "bright white". I welcome this change, especially for tables and table headers, as these are the areas users focus on most.
However, the text in the left main menu is now brighter too. This is not a big issue, but when I look at the GitLab dark theme, for example, I notice a pattern: dimmed text for menus and brighter text for the main content.
A good dark theme needs a careful mix of dimmed and bright text. It is not simply a choice between all bright or all dimmed. Small, subtle decisions matter. These little details can make a dark theme succeed or fail.
This was a good first step. Thank you for that! It makes the dark theme a little more usable, but there is still room for improvement.
Please keep the changes coming. Only by making changes can WinBox improve. It is not finished yet. :flexed_biceps:
Any progress to Winbox 4, is welcomed, regardless how small these changes are. Small changes is exactly the right pace.
I don’t think I fully understand what you’re looking for.
Are you asking for RouterOS to fetch updates from the Internet via some kind of proxy—using Winbox, which connects to RouterOS, as that proxy?
That seems to conflate the concepts of what Winbox is and what RouterOS is, don’t you think? It’s as if you’re treating Winbox like a "reverse" VPN.
It might sound convenient, but in my view, there are dozens of ways this could go wrong.
I would like to see winbox CMR interface same as web version which is IMHO much better.
Can you search/load for workspaces layouts files and settings file, in the same path than currently opened addresses.cdb ???
In my opinion MikroTik should focus on WebFig. WebFig is much more universal. You can access it from any device with screen and a browser. 1:0 WebFig. WinBox is something for the pro users managing more than a handful of devices.
And one feature which would give WB4 a lead, but still missing:
Table columns sized to the content width by default. Without "double click" on the table column separator.
As a user I want, when I first time (=never visited before in active session) open a WinBox window/screen, properly see the data.
As a user I do not want to spend my time on double clicking to just see the data I am looking for.
And I do not understand why this was not implemented in more than 2 years (or 3?) of WB4.
Having this - and proper (I mean: a little more than absolute basic) window management features (instead of floating windows) would be 2 major improvements over WB3. It is not even possible to say "keep window always on top". No way to align windows side-by-side, tiled, or whatever. All must be done by mouse. Not even keyboard keys to resize the windows. Nothing. If "Win" does really stand for "Windows" then please make some improvements in that regard.
