yes, but this is not very convenient and does not organize the list. folders would be more convenient
I’m guessing you are over-using the static DNS feature and it is a disaster waiting to happen…
Consider registering a domain for your organization and putting the records there, or using a local server that is more optimized to serve as a DNS server.
I use DNS Static for FWD to create an addresslist.
Then why do you have so many names that you cannot manage it anymore?
Version 4.0rc1 has been released:
Hi, why is my history always empty since I started using WinBox 4 in all versions, including the new RC, on different Windows PCs?
Now the file dialog uses the system native window! Worked very well (both upload and download) with Mint Cinammon.
There is only one little detail: we can’t change the file name on the dialog window - this have to be done on the router, before the download, or on the OS, before the upload.
But worked very well here.
Can also confirm it's working well from Arch Linux with Gnome
I know this is a user forum, but since some MikroTik developers also read along, I’m posting this here:
Feature request for WinBox 4.x
Please consider adding an “ARP Ping” option to the context menu (right-click) of an entry in IP → ARP List in one of the upcoming WinBox 4.x versions.
When selecting this option, WinBox should automatically open the Ping dialog with the following fields pre-filled:
IP address
Interface
“arp ping” checkbox enabled
This would make it quick and convenient to test reachability of an IP address via ARP ping directly from the ARP list.
Thank you for considering this improvement.
