With the row padding option set to 0 I get the required density of table rows and I start to like the new Winbox and actually using it.
Please reconsider the font used for table values: The decimal dots are tiny and almost invisible between the digits. This makes reading of IP addresses and speeds unnecessary hard. A fixed with font for table values would be much easier to read.
New windows or prompt boxes open on the upper left corner of the screen unlike Winbox 3 where they opened in the middle.
Example: On interface window click on new and select PPP Client then the new window open on the upper left corner of the screen and itās the same behavior for everything else.
Bug:
Winbox 4.0Beta16
Windows 11 24H2
When I have a workspace for a physical router that I have windows open that are specific to that router (like health window) and are not available on CHR router then if I try to open a CHR router with same workspace I get the following error:
Agree itās annoying you cannot filter by ports. But itās also a problem in CLI/APIs too, since you cannot filter by port there either. So not exactly winbox4 specific ā although winbox4 certainly could do some client-side parsing of ports.
It be better if /ip/firewall/connectionās ports were stored as separate attributes, instead just one ā that likely automatically carryover to winbox/webfix since all UIs use same CLI/API attributes to display.
They are getting somewhere with the last betas, but Iām still struggling getting used to these new ācommentsā.
After YEARS of tweaking comments in many ways to help readability (Iām talking about very complex setups with MANY rules), now itās almost impossible to adapt/port the same stuff.
I would like, at least, the possibility to add DUMMY lines with text (best with colors as well ..like pfSense does)
I do almost the same, ādummyā chain for all (long) comment but the problem is that if I disable inline-comment for firewall .. itās a readability mess in all other windows which are tuned for inline-comment (on). I have to switch back and forth ā or back to winbox3 were this setting is not global.
In any case, our custom tweaks are obviously not included in MT thoughs when they design it; it would be better to have something that is dedicated and designed for it.
I think that the pfSense example can be a good starting point.
I just upgraded to Winbox 4 and (beta 16), routeros 7.17 and I have a multiline system note that uses whitespace to format some large ACII text.
In Winbox 3, this displayed correctly using the same font as the terminal does when the system note is displayed on the GUI.
In Winbox 4, the whitespace is not displayed consistently, and space characters are compressed at login on the GUI. The terminal still shows it correctly.
Looks like the wrong font was used to display the system notes at Winbox login. Is there any way to get it to use a proper terminal font like it did in earlier versions?
Itās so funny to hear about āimprovementsā.
Where are these improvements? From the very beginning almost all changes are related to fixing the bugs and fixing consequences of silly āmodern designā decisions. And even despite of this, there are still lots of problems and itās still worse and inconvenient compared to WinBox 3.
Though, to be fair, I like 2 things: ability to hide tabs that you donāt need, and ability to collapse/expand directories in the File List.
May be itās good for some people, but considering that there is a wine, itās not a big improvement. It doesnāt affect the app functionality. And the app was called WinBox, its name says for itself.
