Winbox 4 problems
Hi, for some reason I can’t reply (no buttons to post reply) in original announcement thread so had to create a new one, adding to the list of caveats:
  1. https://imgur.com/a/gs2dxQm the most annoying and rookie UI mistake, should have slight delay between switching popup menus so you can take shortest path with mouse
  2. a lot of options missing from right click menu like “Comment”, etc. It is good alternative to hotkeys to get stuff done with minimum mouse movement
  3. no more option “connect to all” when selecting multiple saved devices from main connection screen
  4. no more sorting by comment on main connection screen
Agree with 1) especially. Delay may help a little. In web applications one technique is drawing an invisible triangle from active menu item to submenu panel. So it can’t trigger items hover on items below. People usually move the cursor not perfectly horizontally, especially when moving cursor towards an item on the bottom end of submenu.
I don’t won’t to sound hard either, but many people waited very long time for a new Winbox. And then it is full of UI/UX rookie mistakes. Hard to swallow.
  1. There is sorting by comment. First expand comment field by clicking on the header.
Its not possible from the main (connection screen). There is no option to enable “comments” as a column.
