I am new to Microtik products having only used consumer routers up to this
I purchased a Microtik RB951G-2HnD and used winbox to configure it I am basically using it as a home router and its working great so far
in the quickset screen there is a section for 2 wireless networks one main one and a guest network you can limit download on guest and I have done this and it works but I would like to know if guest network is isolated from main network ie does it only have internet access
I really find it a steep learning curve but the router is so much flexible than normal consumer routers
I dont’t use such funtionality, but you can easily test that by yourself: link to guest network and try to connect to you lan/main network (ping, whatever..).
Surely you can achieve that goal with mt gears using normal config tools (not ‘wizard’ stuff, which I don’t use), so I guess ..
.. maybe someone more skilled than me can give you more hints..
