Hi Yazzy
That’s correct it uses mysql.
Here is the sql.conf
Configuration for the SQL module, when using MySQL.
The database schema is available at:
src/radiusd/src/modules/rlm_sql/drivers/rlm_sql_mysql/db_mysql.sql
If you are using PostgreSQL, please use ‘postgresql.conf’, instead.
If you are using Oracle, please use ‘oracle.conf’, instead.
If you are using MS-SQL, please use ‘mssql.conf’, instead.
$Id: sql.conf,v 1.41.2.1 2004/06/10 00:45:01 phampson Exp $
sql {
Database type
Current supported are: rlm_sql_mysql, rlm_sql_postgresql,
rlm_sql_iodbc, rlm_sql_oracle, rlm_sql_unixodbc, rlm_sql_freetds
driver = “rlm_sql_mysql”
Connect info
server = “localhost”
login = “xxxxx”
password = “xxxxx”
Database table configuration
radius_db = “xxxxx”
If you want both stop and start records logged to the
same SQL table, leave this as is. If you want them in
different tables, put the start table in acct_table1
and stop table in acct_table2
acct_table1 = “radacct”
acct_table2 = “radacct”
Allow for storing data after authentication
postauth_table = “radpostauth”
authcheck_table = “radcheck”
authreply_table = “radreply”
groupcheck_table = “radgroupcheck”
groupreply_table = “radgroupreply”
usergroup_table = “usergroup”
Remove stale session if checkrad does not see a double login
deletestalesessions = yes
Print all SQL statements when in debug mode (-x)
sqltrace = yes
sqltracefile = ${logdir}/sqltrace.sql
number of sql connections to make to server
num_sql_socks = 5
number of seconds to dely retrying on a failed database
connection (per_socket)
connect_failure_retry_delay = 60
Safe characters list for sql queries. Everything else is replaced
with their mime-encoded equivalents.
The default list should be ok
#safe-characters = “@abcdefghijklmnopqrstuvwxyzABCDEFGHIJKLMNOPQRSTUVWXYZ0123456789.-_: /”
Query config: Username
This is the username that will get substituted, escaped, and added
as attribute ‘SQL-User-Name’. ‘%{SQL-User-Name}’ should be used below
everywhere a username substitution is needed so you you can be sure
the username passed from the client is escaped properly.
Uncomment the next line, if you want the sql_user_name to mean:
Use Stripped-User-Name, if it’s there.
Else use User-Name, if it’s there,
Else use hard-coded string “DEFAULT” as the user name.
#sql_user_name = “%{Stripped-User-Name:-%{User-Name:-DEFAULT}}”
sql_user_name = “%{User-Name}”
Default profile
This is the default profile. It is found in SQL by group membership.
That means that this profile must be a member of at least one group
which will contain the corresponding check and reply items.
This profile will be queried in the authorize section for every user.
The point is to assign all users a default profile without having to
manually add each one to a group that will contain the profile.
The SQL module will also honor the User-Profile attribute. This
attribute can be set anywhere in the authorize section (ie the users
file). It is found exactly as the default profile is found.
If it is set then it will overwrite the default profile setting.
The idea is to select profiles based on checks on the incoming packets,
not on user group membership. For example:
– users file –
DEFAULT Service-Type == Outbound-User, User-Profile := “outbound”
DEFAULT Service-Type == Framed-User, User-Profile := “framed”
By default the default_user_profile is not set
#default_user_profile = “DEFAULT”
Determines if we will query the default_user_profile or the User-Profile
if the user is not found. If the profile is found then we consider the user
found. By default this is set to ‘no’.
#query_on_not_found = no
Authorization Queries
These queries compare the check items for the user
in ${authcheck_table} and setup the reply items in
${authreply_table}. You can use any query/tables
you want, but the return data for each row MUST
be in the following order:
0. Row ID (currently unused)
1. UserName/GroupName
2. Item Attr Name
3. Item Attr Value
4. Item Attr Operation
Use these for case sensitive usernames. WARNING: Slower queries!
authorize_check_query = “SELECT id,UserName,Attribute,Value,op FROM ${authcheck_table} WHERE STRCMP(Username, ‘%{SQL-User-Name}’) = 0 ORDER BY id”
authorize_reply_query = “SELECT id,UserName,Attribute,Value,op FROM ${authreply_table} WHERE STRCMP(Username, ‘%{SQL-User-Name}’) = 0 ORDER BY id”
authorize_check_query = “SELECT id,UserName,Attribute,Value,op FROM ${authcheck_table} WHERE Username = ‘%{SQL-User-Name}’ ORDER BY id”
authorize_reply_query = “SELECT id,UserName,Attribute,Value,op FROM ${authreply_table} WHERE Username = ‘%{SQL-User-Name}’ ORDER BY id”
Use these for case sensitive usernames. WANRING: Slower queries!
authorize_group_check_query = “SELECT ${groupcheck_table}.id,${groupcheck_table}.GroupName,${groupcheck_table}.Attribute,${groupcheck_table}.Value,${groupcheck_table}.op FROM ${groupcheck_table},${usergroup_table} WHERE STRCMP(${usergroup_table}.Username, ‘%{SQL-User-Name}’) = 0 AND ${usergroup_table}.GroupName = ${groupcheck_table}.GroupName ORDER BY ${groupcheck_table}.id”
authorize_group_reply_query = “SELECT ${groupreply_table}.id,${groupreply_table}.GroupName,${groupreply_table}.Attribute,${groupreply_table}.Value,${groupreply_table}.op FROM ${groupreply_table},${usergroup_table} WHERE STRCMP(${usergroup_table}.Username, ‘%{SQL-User-Name}’) = 0 AND ${usergroup_table}.GroupName = ${groupreply_table}.GroupName ORDER BY ${groupreply_table}.id”
authorize_group_check_query = “SELECT ${groupcheck_table}.id,${groupcheck_table}.GroupName,${groupcheck_table}.Attribute,${groupcheck_table}.Value,${groupcheck_table}.op FROM ${groupcheck_table},${usergroup_table} WHERE ${usergroup_table}.Username = ‘%{SQL-User-Name}’ AND ${usergroup_table}.GroupName = ${groupcheck_table}.GroupName ORDER BY ${groupcheck_table}.id”
authorize_group_reply_query = “SELECT ${groupreply_table}.id,${groupreply_table}.GroupName,${groupreply_table}.Attribute,${groupreply_table}.Value,${groupreply_table}.op FROM ${groupreply_table},${usergroup_table} WHERE ${usergroup_table}.Username = ‘%{SQL-User-Name}’ AND ${usergroup_table}.GroupName = ${groupreply_table}.GroupName ORDER BY ${groupreply_table}.id”
Accounting Queries
accounting_onoff_query - query for Accounting On/Off packets
accounting_update_query - query for Accounting update packets
accounting_update_query_alt - query for Accounting update packets
(alternate in case first query fails)
accounting_start_query - query for Accounting start packets
accounting_start_query_alt - query for Accounting start packets
accounting_stop_query - query for Accounting stop packets
accounting_stop_query_alt - query for Accounting start packets
(alternate in case first query doesn’t
affect any existing rows in the table)
accounting_onoff_query = “UPDATE ${acct_table1} SET AcctStopTime=‘%S’, AcctSessionTime=unix_timestamp(‘%S’) - unix_timestamp(AcctStartTime), AcctTerminateCause=‘%{Acct-Terminate-Cause}’, AcctStopDelay = ‘%{Acct-Delay-Time}’ WHERE AcctSessionTime=0 AND AcctStopTime=0 AND NASIPAddress= ‘%{NAS-IP-Address}’ AND AcctStartTime <= ‘%S’”
accounting_update_query = “UPDATE ${acct_table1}
SET FramedIPAddress = ‘%{Framed-IP-Address}’,
AcctSessionTime = ‘%{Acct-Session-Time}’,
AcctInputOctets = ‘%{Acct-Input-Octets}’,
AcctOutputOctets = ‘%{Acct-Output-Octets}’
WHERE AcctSessionId = ‘%{Acct-Session-Id}’
AND UserName = ‘%{SQL-User-Name}’
AND NASIPAddress= ‘%{NAS-IP-Address}’”
accounting_update_query_alt = “INSERT into ${acct_table1} (AcctSessionId, AcctUniqueId, UserName, Realm, NASIPAddress, NASPortId, NASPortType, AcctStartTime, AcctSessionTime, AcctAuthentic, ConnectInfo_start, AcctInputOctets, AcctOutputOctets, CalledStationId, CallingStationId, ServiceType, FramedProtocol, FramedIPAddress, AcctStartDelay) values(‘%{Acct-Session-Id}’, ‘%{Acct-Unique-Session-Id}’, ‘%{SQL-User-Name}’, ‘%{Realm}’, ‘%{NAS-IP-Address}’, ‘%{NAS-Port}’, ‘%{NAS-Port-Type}’, DATE_SUB(‘%S’,INTERVAL (%{Acct-Session-Time:-0} + %{Acct-Delay-Time:-0}) SECOND), ‘%{Acct-Session-Time}’, ‘%{Acct-Authentic}’, ‘’, ‘%{Acct-Input-Octets}’, ‘%{Acct-Output-Octets}’, ‘%{Called-Station-Id}’, ‘%{Calling-Station-Id}’, ‘%{Service-Type}’, ‘%{Framed-Protocol}’, ‘%{Framed-IP-Address}’, ‘0’)”
accounting_start_query = “INSERT into ${acct_table1} (AcctSessionId, AcctUniqueId, UserName, Realm, NASIPAddress, NASPortId, NASPortType, AcctStartTime, AcctStopTime, AcctSessionTime, AcctAuthentic, ConnectInfo_start, ConnectInfo_stop, AcctInputOctets, AcctOutputOctets, CalledStationId, CallingStationId, AcctTerminateCause, ServiceType, FramedProtocol, FramedIPAddress, AcctStartDelay, AcctStopDelay) values(‘%{Acct-Session-Id}’, ‘%{Acct-Unique-Session-Id}’, ‘%{SQL-User-Name}’, ‘%{Realm}’, ‘%{NAS-IP-Address}’, ‘%{NAS-Port}’, ‘%{NAS-Port-Type}’, ‘%S’, ‘0’, ‘0’, ‘%{Acct-Authentic}’, ‘%{Connect-Info}’, ‘’, ‘0’, ‘0’, ‘%{Called-Station-Id}’, ‘%{Calling-Station-Id}’, ‘’, ‘%{Service-Type}’, ‘%{Framed-Protocol}’, ‘%{Framed-IP-Address}’, ‘%{Acct-Delay-Time}’, ‘0’)”
accounting_start_query_alt = “UPDATE ${acct_table1} SET AcctStartTime = ‘%S’, AcctStartDelay = ‘%{Acct-Delay-Time}’, ConnectInfo_start = ‘%{Connect-Info}’ WHERE AcctSessionId = ‘%{Acct-Session-Id}’ AND UserName = ‘%{SQL-User-Name}’ AND NASIPAddress = ‘%{NAS-IP-Address}’”
accounting_stop_query = “UPDATE ${acct_table2} SET AcctStopTime = ‘%S’, AcctSessionTime = ‘%{Acct-Session-Time}’, AcctInputOctets = ‘%{Acct-Input-Octets}’, AcctOutputOctets = ‘%{Acct-Output-Octets}’, AcctTerminateCause = ‘%{Acct-Terminate-Cause}’, AcctStopDelay = ‘%{Acct-Delay-Time}’, ConnectInfo_stop = ‘%{Connect-Info}’ WHERE AcctSessionId = ‘%{Acct-Session-Id}’ AND UserName = ‘%{SQL-User-Name}’ AND NASIPAddress = ‘%{NAS-IP-Address}’”
accounting_stop_query_alt = “INSERT into ${acct_table2} (AcctSessionId, AcctUniqueId, UserName, Realm, NASIPAddress, NASPortId, NASPortType, AcctStartTime, AcctStopTime, AcctSessionTime, AcctAuthentic, ConnectInfo_start, ConnectInfo_stop, AcctInputOctets, AcctOutputOctets, CalledStationId, CallingStationId, AcctTerminateCause, ServiceType, FramedProtocol, FramedIPAddress, AcctStartDelay, AcctStopDelay) values(‘%{Acct-Session-Id}’, ‘%{Acct-Unique-Session-Id}’, ‘%{SQL-User-Name}’, ‘%{Realm}’, ‘%{NAS-IP-Address}’, ‘%{NAS-Port}’, ‘%{NAS-Port-Type}’, DATE_SUB(‘%S’, INTERVAL (%{Acct-Session-Time:-0} + %{Acct-Delay-Time:-0}) SECOND), ‘%S’, ‘%{Acct-Session-Time}’, ‘%{Acct-Authentic}’, ‘’, ‘%{Connect-Info}’, ‘%{Acct-Input-Octets}’, ‘%{Acct-Output-Octets}’, ‘%{Called-Station-Id}’, ‘%{Calling-Station-Id}’, ‘%{Acct-Terminate-Cause}’, ‘%{Service-Type}’, ‘%{Framed-Protocol}’, ‘%{Framed-IP-Address}’, ‘0’, ‘%{Acct-Delay-Time}’)”
Simultaneous Use Checking Queries
simul_count_query - query for the number of current connections
- If this is not defined, no simultaneouls use checking
- will be performed by this module instance
simul_verify_query - query to return details of current connections for verification
- Leave blank or commented out to disable verification step
- Note that the returned field order should not be changed.
Uncomment simul_count_query to enable simultaneous use checking
simul_count_query = “SELECT COUNT(*) FROM ${acct_table1} WHERE UserName=‘%{SQL-User-Name}’ AND AcctStopTime = 0”
simul_verify_query = “SELECT RadAcctId, AcctSessionId, UserName, NASIPAddress, NASPortId, FramedIPAddress, CallingStationId, FramedProtocol FROM ${acct_table1} WHERE UserName=‘%{SQL-User-Name}’ AND AcctStopTime = 0”
Group Membership Queries
group_membership_query - Check user group membership
group_membership_query = “SELECT GroupName FROM ${usergroup_table} WHERE UserName=‘%{SQL-User-Name}’”
Authentication Logging Queries
postauth_query - Insert some info after authentication
postauth_query = “INSERT into ${postauth_table} (id, user, pass, reply, date) values (‘’, ‘%{User-Name}’, ‘%{User-Password:-Chap-Password}’, ‘%{reply:Packet-Type}’, NOW())”
Set to ‘yes’ to read radius clients from the database (‘nas’ table)
#readclients = yes
I think I have, whereabouts is it set ?
