Winbox and 2 WAN feeds
Recent install is a RB1200
I have a Firewall filter rule to accept
add action=accept chain=input comment=Winbox disabled=no dst-port=8291 protocol=tcp
It works.
I am using ports 9 and 10 for the WAN connections.
There are 2 DSL modems fed into the router.
Using mangle and routes I have traffic divided.
Both DSL modems have DYNdns addresses on them.
When i have both connections working… I can only WInbox in on Port 10.
As soon as port 10 goes dead I can winbox on Port 9
Reconnect Port 10 and if I am on Winbox via Port 9… I get kicked.
Any ideas?
You need to setup policy routing so when you come in on one wan connection you go out on the same wan. Right now you are coming in one interface and using the default route and going out the other wan interface.
There are a few articles out there but here is one.
http://wiki.mikrotik.com/wiki/Manual:PCC#Policy_routing
Dear all
I am using mikrotik 751 -2 h routerboard in my college campus with hotspot solution ..i am facing lot of problems they are
1.if i create 15 min coupon its is not expired after 15 min and same 30min ,24 hours also …
2.userman time is lessthan actual time (we want INDIA time ).
3. kindly help me to make success in my college campus …
thanks
viswa yk
What does this have to do with this thread? You need to create your own thread.
But I don’t understand why it would shunt me to the other Feed.
Is the output section the most important part of that article?
