HI,
I’m using port knocking on my routers. When I want to log in to router, first I have to knock using webbrowser http://my-router:3500
Could you add to winbox option called knock port. Before connect, first winbox will knock port.
HI,
Ok, but why don’t built in winbox knock tool?
Ah, you were looking for a client tool… I misundestood your question.
The best you can do is to make a script in your preferred language to knock an then invoke winbox (on the command line you can put address, user and password), or create a more complex gui yourself.
