I usually open a telnet session from neighbours in a winbox session.
First problem is that telnet opens and goes to the back, so you have to click on it to start using it.
When using this telnet session, all text seems to write in the last line, no scrolling. So I change telnet window size, and re enter last command. I see the result right, but if I enter another command, it’ll write it again in the last line, no scrolling. So I have to resize window each time if I want to see the text each command produces…
It’s very annoying!!!
