Winbox cannot connect to mac-address:
why?
why?
Should it? Do you have MAC-WinBox service enabled on the port you are trying to connect to?
MAC-WinBox service???
Yes. Check the /tool mac-server mac-winbox menu. You can disable/enable it there for the interfaces you need mac-server to respond on.
