Hey all.
I have run into a problem, when WinBox cant see or connect to my wAP after I make it to be both CAPsMAN and CAP. My setup:
I have three units total, one wAP (being CAPsMAN) and two cAP(CAPs).
When wAP is configured as default router(CAPsMAN) and two cAP(CAPs) - i can connect to all of them individually - everything works fine. But when I make wAP to be both CAPsMAN and CAP the WiFi works and after connecting to it’s SSID I can go online, but i cannot connect to wAP anymore. I have tried looking under “Neighbors” - none, checked out the IP issued from my switch - 192.168.1.72 i can see the device is active, but even after i connect through switch to wAP and using wAP’s IP WinBox is not connecting to the device. So i have to reset it to default and restore to configurations, just before i turn it to act both as MAN and CAP.
What’s weird is that while configuring CAPsMAN, DHCP which I have set for bridge interface is 10.10.10.0. But when i connect to WiFi network created by CAPsMAN and check the IP i m receiving - it’s 192.168.1.65 (which is my switch’s DHCP range) as though it connects me to my switch instead of assigning an IP from configured IP pool (10.10.10.2-10.10.10.254).
Please help me to understand what am I doing wrong or missing out.
My configurations before I set wAP to be CAP
[admin@MikroTik - office] > /ip dhcp print
Flags: D - dynamic, X - disabled, I - invalid
# NAME INTERFACE RELAY ADDRESS-POOL LEASE-TIME ADD-ARP
0 defconf wlan1 dhcp 10m
1 dhcp1 OfficeNet dhcp_pool4 10m
[admin@MikroTik - office] > /ip pool print
# NAME RANGES
0 dhcp 10.0.0.2-10.0.0.254
1 guest-wifi 10.1.1.2-10.1.1.50
2 dhcp_pool3 10.10.10.2-10.10.10.254
3 dhcp_pool4 10.10.10.2-10.10.10.254
[admin@MikroTik - office] > caps-man configuration print
0 name="OfficeNet" mode=ap ssid="meshpower-office" datapath.bridge=OfficeNet
1 name="GuestNet" mode=ap ssid="meshpower-guest" security=GuestNet datapath=VLAN-GuestNet
[admin@MikroTik - office] > caps-man provisioning print
Flags: X - disabled
0 radio-mac=00:00:00:00:00:00 hw-supported-modes="" identity-regexp="" common-name-regexp="" ip-address-ranges="" action=create-dynamic-enabled master-configuration=OfficeNet
slave-configurations=GuestNet name-format=prefix name-prefix="OfficeAP"
[admin@MikroTik - office] > caps-man datapath print
0 name="VLAN-OfficeNet" client-to-client-forwarding=yes bridge=OfficeNet local-forwarding=yes vlan-mode=use-tag vlan-id=10
1 name="VLAN-GuestNet" client-to-client-forwarding=yes bridge=OfficeNet local-forwarding=yes vlan-mode=use-tag vlan-id=20
[admin@MikroTik - office] > caps-man security print
0 ;;; password for guest network - meshpowerguest
name="GuestNet" authentication-types=wpa-psk,wpa2-psk encryption=aes-ccm passphrase="meshpowerguest"
[admin@MikroTik - office] > /ip address print
# ADDRESS NETWORK INTERFACE
0 ;;; defconf
10.0.0.1/24 10.0.0.0 wlan1
1 10.10.10.1/24 10.10.10.0 OfficeNet
2 D 192.168.1.72/24 192.168.1.0 ether1
[admin@MikroTik - office] > interface bridge print
0 R name="OfficeNet" mtu=1500 actual-mtu=1500 l2mtu=1598 arp=enabled arp-timeout=auto mac-address=6C:3B:6B:63:25:1B protocol-mode=rstp fast-forward=no igmp-snooping=no priority=0x8000
auto-mac=yes max-message-age=20s forward-delay=15s transmit-hold-count=6 ageing-time=5m region-name="" region-revision=0 max-hops=20 vlan-filtering=no pvid=1
[admin@MikroTik - office] > interface bridge port print
Flags: X - disabled, I - inactive, D - dynamic, H - hw-offload
# INTERFACE BRIDGE HW PVID PRIORITY PATH-COST INTERNAL-PATH-COST HORIZON
0 I OfficeAP2-1 *8 yes 1 0x80 10 10 none
1 H ether1 OfficeNet yes 1 0x80 10 10 none
[admin@MikroTik - office] > /ip route print
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf, m - mme, B - blackhole, U - unreachable, P - prohibit
# DST-ADDRESS PREF-SRC GATEWAY DISTANCE
0 ADS 0.0.0.0/0 192.168.1.254 1
1 ADC 10.0.0.0/24 10.0.0.1 wlan1 0
2 ADC 10.10.10.0/24 10.10.10.1 OfficeNet 0
3 ADC 192.168.1.0/24 192.168.1.72 OfficeNet 0
[admin@MikroTik - office] > /ip firewall filter print
0 D ;;; special dummy rule to show fasttrack counters
chain=forward action=passthrough
1 ;;; allows user manager to work with local hosts
chain=input action=accept src-address=127.0.0.0/24 log=no log-prefix=""
2 ;;; place hotspot rules here
chain=unused-hs-chain action=passthrough log=no log-prefix=""
3 ;;; defconf: accept established,related,untracked
chain=input action=accept connection-state=established,related,untracked log=no log-prefix=""
4 ;;; defconf: drop invalid
chain=input action=drop connection-state=invalid log=no log-prefix=""
5 ;;; defconf: accept ICMP
chain=input action=accept protocol=icmp log=no log-prefix=""
6 ;;; defconf: drop all not coming from LAN
chain=input action=drop in-interface-list=!LAN log=no log-prefix=""
7 ;;; defconf: accept in ipsec policy
chain=forward action=accept log=no log-prefix="" ipsec-policy=in,ipsec
8 ;;; defconf: accept out ipsec policy
chain=forward action=accept log=no log-prefix="" ipsec-policy=out,ipsec
9 ;;; defconf: fasttrack
chain=forward action=fasttrack-connection connection-state=established,related log=no log-prefix=""
10 ;;; defconf: accept established,related, untracked
chain=forward action=accept connection-state=established,related,untracked log=no log-prefix=""
11 ;;; defconf: drop invalid
chain=forward action=drop connection-state=invalid log=no log-prefix=""
12 ;;; defconf: drop all from WAN not DSTNATed
chain=forward action=drop connection-state=new connection-nat-state=!dstnat in-interface-list=WAN log=no log-prefix=""
13 ;;; CAPSMANAGER Discovery
chain=input action=accept protocol=udp src-port=5246,5247
14 ;;; CAPSMANAGER Discovery
chain=input action=accept protocol=udp dst-port=5246,5247
[admin@MikroTik - office] > /ip firewall nat print
0 X ;;; place hotspot rules here
1 ;;; defconf: masquerade
chain=srcnat action=masquerade out-interface-list=WAN ipsec-policy=out,none
2 X ;;; masquerade hotspot network
chain=srcnat action=masquerade src-address=192.168.88.0/24 log=no log-prefix=""
3 X chain=srcnat action=masquerade out-interface=wlan1 log=no log-prefix=""
4 chain=srcnat action=masquerade src-address=10.10.10.0/24 log=no log-prefix=""
5 chain=srcnat action=masquerade out-interface=all-wireless log=no log-prefix=""
