Hi everyone
I can’t login to my router (RB750) using IP address, and it’s only can log with MAC address. then when it logged in. it disconnect suddenly in short time after login or long time.
I’m in office network and i get IP from router as DHCP server.
It’s Important when i wanna login to router from out of company.
Please help
Download New Winbox Tool and try again.
let me know if it works.
No it doesn’t work for me
The default TCP port for winbox is 8291, do you see 8291 TCP port from your PC?
Do you ping the IP address of your Mikrotik router?
If Telnet is not blocked, try it and make sure your problem is only with winbox, not other protocols such as Telnet, SSH, …
Sounds like a different network. If you cannot connect via IP then it’s an IP conflict in the addressing or routing.
Example your ip is 192.168.233.2 but the IP of the router is 172.233.212.1
Unless you have the routing setup right you ain’t never talking to the router on that one. You’d need static route added that told the router the 192 network is available via X link.
If you are trying to understand networking, instead of dick around and bullshit yourself; take CISCO CCNA classes at a community college. Costs nothing and you will understand networking from the ground up, for the rest of your life.
thanks fluxburn
your right CCNA is useful but It’s because of a mistake in firewall configuration, in wiki i copy the bogons IP list ithout attention & block them. one of them is 192.168.0.0/16 & the default IP for router is 192.168..88.0/24 then …
thanks to support@mikrotik i find it.
