So I store my winbox.exe on my onedrive and manually pin it to start so I know I always have it no matter what system I’m on and can update all of them with just replacing the single exe.
However, it seems that winbox stores its configuration data in I’m assuming AppData someplace?
So I constantly have to export and import my router address and credentials lists every time I add a new device, which is almost daily.
Because if I have to go on location and use my laptop only to realize the contact was entered in on my desktop and I didn’t export it, and import it into my laptop now I’m on-site without credentials.. etc…
Is there any flag that can specify a config location when launching the exe so that the app is more portable and just saves the config information to the same folder the exe is in rather than storing it on each device individually?
