Winbox crashing after upgrade to 2.9.12
We have lots of winbox crashes after upgrading to 2.9.12. Using Win2k
I have had 2.9.12 winbox crash on me, but only after hitting close …
Sam
This is supposed to be corrected in the next RouterOS release…
Best regards,
Christian Meis
Good to hear
can anyone confirm that winbox does not crash in 2.9.13? I did no t see it listed in the change log.
Well, at least it doesn’t crash for me on three systems anymore…
Best regards,
Christian Meis
You should use latest Winbox loader ( 2.2.8 ). Then use tools → Clear cache, just in case. And there shoudn’t be any problems at all.
If you have problems with MAC-winbox through some interface
  • check your firewall settings on the PC
  • make sure that it is only active interface on your laptop or PC
