Winbox Discovery of Devices
Two issues I want to discuss.
A. In Winbox, I cannot access devices by IP address, I have to use MAC addresses.
Its not a big deal but it may be a contributor to the other issue. This applies to the Router and to the CapACs. The switches are direct via IP on the browser and simply work.
B. When I fire up Winbox, I can see
-router
-260GS switch
-260GSP switch
-capac2
However I cannot see my capac1 and cannot figure out why not??
Network Information:
  1. All devices get DHCP from homevlan XX.
  2. All devices have a pvid of 1 as the default (on switches and on bridges of router and capacs)
  3. Capac2: router to 24port dlink switch to capac2
  4. Capac1: router to Dlink switch to 260GSP switch to capac1
  5. I cannot discern any difference of the bridge setup on either capac.
Conclusion, there is some setting on the 260GSP switch or DLINK switch that may be preventing visibility of the capac to the router.
Looking at my excel sheet of port and device connectivity it appears I may not have identified port 1 on the etherport of the dlink switch heading to the 260GSP.
Okay that was a false lead, all the trunk ports on the Dlink switch have the native vlan set as 1, the trunk allowed vlans in associated ports do not include vlan1, ingress checking is enabled and admit all frames types is enabled. Since this is the same for all trunk ports including the visible capac2, I am ruling out the DGS-1100 as being the potential source of the issue.
That leaves me pondering the setup of the 260GSP.
VLAN MENU:
  1. Trunk port on Switch is on the SFP port.
    {ingress}
    Vlanmode=enabled
    Vlanreceive=any
    DefaultVlan=1
    {egress}
    Vlanheader= leave as is
  2. Capac1 port on Switch is on Port 3 (poe fluctuates between 169-174mA, and 4.0-4.1W)
    {ingress}
    Vlanmode=enabled
    Vlanreceive=any
    DefaultVlan=1
    {egress}
VLANS MENU:
VLANID=1 [To CapAC1] =Leave as is / Fm DlinkSwitch] =Leave as is
VLANID=XX [To CapAC1] =Leave as is / Fm DlinkSwitch] =Leave as is
Nothing I can see that should lead me to suspect the switch.
Perplexed!
A. Maybe you were too paranoid with firewall (chain=input)?
Guesses are free so why not! :stuck_out_tongue_winking_eye:
However it would have to be a specific rule to stop one capac from being visible and not the other… Oh you are talking about the mac vs IP issue (1).
That sounds very plausible.
However, one of the first rules in my input chain is ALLOW ADMIN TO ROUTER
add chain=input action=accept in-interface-list=RBWIN source-address-list=admin access
RBWIN identifies two VLAN entities, one being my homelan (that my PC is on) and the other is a second subnet that I need access from when troubleshooting.
admin address list identifies the exact IP addresses within the above vlan entities.
So based on that, why would any of my traffic be blocked???
Okay when I looked at IP services I discovered why…
I do not have the default Winbox port setup as I replaced it long ago.
Double checking, when i Put in IP_ADDRESS:current-wboxport NOW I GET ACCESS via IP LOL.
Still need help though on the capac1 issue!
Other guesses … for free
