I have a problem with winbox software.
The routerboard is a 532 with a 8602 radio 400mW.
I run the winbox.exe and i can connect to the routerboard 532, but some functions are disable.
Ej: I put an ip address to the bridge and reboot. After, I connect via winbox but I cannot see the ip address or I cannot see the ports and I cannot add the ports to the bridge…
The rb 532 software is 2.9.30 and all packages are active.
However, I only can to configure the rb if I´m connected in the same switch. The options are disabled and I cannot to configure any option.
I´m really desperate…
The rb software is v2.9.30 and Im connecting throught the lastest winbox version. The problem is the same. Now, I connect via winbox(port 20561) and the problem is the same. But, if I connect throught dude with winbox (port 8291) the problem is resolute. In this manner its working correctly.
