WinBox does not retain size
Please fix this anoying bug:
Winbox cannot remember it’s size, and it cannot be maximized. We are some with a lot of routers :wink:
KimC
I have to say… I just maximised it on BOTH my screens.
On a 15 inch and one a 17 inch flat screen..
And I am sorry to say I logged out and logged back in - and it remembered its size correctly.
SO - maybe you have a display driver issue. Winbox is fine here.
It was ok with 2.8.27 and is ok with 2.9rc2.
I have to admit I am new to MT (two or three weeks) but seems fine.
Sorry not to help but no bug here.
Cheers.
Yes, its true. Not save size and position. Not other, this is winbox bug.
Sorry, I did not make my self clear.
The problem is in the WinBox loader - not WinBox it self.
KimC
kimc
you can create a shortcut to winbox and then edit the short cut to run maximized that does work but yes it would be nice to even creat folders for different groups of MT’s for management purposes/
randy
