whene i use pppoe conection in windows vista
i cant log in mikrotik server
i disable firewall but tahe same problem
up
“up” what? your problem description is so unclear that nobody can answer to this. give us a network diagram, and sell us what exactly doesn’t work
He posted a reply purely in order to raise the thread to the top of the list of active threads. Thread bumping is commonly considered a breach of netiquette and some moderated forums forbid it.
i am pretty sure normis is well aware of the intention of the post.
hence the reply - user does not get the answer because question is stated in wrong way. Hence, the post where he asks for more information.
and as we see - there is no more information added about problem at hand. as a result - no solution.
Yes, of course he is. The real purpose of the message was to call attention to the thread owner that this is bad behaviour.
ok
i have a problem
i have router os x86 with hotsopt and pppoe enabled
every thig is good
but i cant login to mikrotik router os by winbox from the pc’s using windows vista and windows 7 and using pppoe
Okey, but you did not gave much more information than before. We should not have to ask twenty questions to get people to tell us what’s wrong with their routers. As normis said, your problem description is unclear at best. To get help with this issue, you need to provide information of your network and router configuration. You said that you cannot login to your router when you are connected with PPPoE. I guess that you are able to connect to your MikroTik router when PPPoE is disconnected? If that is so, did you try to connect using an IP address, or a MAC address?
dear
i said every thing is working good and i login to the server by winbox from any pc using windows xp
but i cant login from any pc have windows vista or windows 7
the problem is simple
any one try to use winbox to login after connect by pppoe from win vista or win 7?
i try to tell all about this problem to solve it
winbox with PPPoE and all Windows including vista 32/64 bit and win7 32/64 bit and MacOSX works fine. ROS version from 2.9.31 to 4.1
Nah, you said nothing about Windows XP. Okey, now we finally know that it only works with Windows XP, but not with any newer Windows versions. It sounds like Windows Vista and Windows 7 is misconfigured.
try to run Winbox as Administrator
i do it but not working
Are you running pppoe on winXP as well when everything is working? You could also disable firewall, see if it helps.
