I have RB3011. It’s working fine, but when I connect by Winbox it shows all pages empty (no interfaces, no addresses and so on).
For SSH connection I can see all.
Also I have some wAPs - WInbox connection for them works fine.
I connect to IP address, not MAC.
WInbox version 3.10.
I deleted ‘Mikrotik’ folder from AppData - it didn’t help.
Source was in network adapter in my computer.
All was fine till today morning, when problem began, I don’t know what triggered it - there was no changes for some months.
But when I turn off all default turned on offloads for TCP/IP in onboard Realtek based network card problem disappears.
Also, as a symptom, - when I clear Winbox cache, program began to download plugins and it was VERY slow - about 1 Kbyte/s ! And this for Gigabit LAN!
Hello
I have this problem, i connecta via VPN L2TP and have this problem
I not use Wifi, via local lan works fine, via VPN show empty, this router not have wireless
any idea?
Update 1:
The problem was large MTU set between two routers and since I was connecting to R2 through R1, I got disconnected continuously. I reduced MTU and problem solved.
Original Post:
I just did the laziest thing I could.
Connected via Winbox and so many empty windows like “ip route”, “ip addresses”, … inside Winbox opened.
From “Session” menu I chose “Close All Windows” and then I exited Winbox.
3 Connected to Winbox again and everything was fine
Just check, that JUMBO packets are not in use on both sides, set your network adapter to Jumbo=disabled. Got same behavior with jumbo set to 2000 on pc. All other (switch, MT) was on standart MTU. Funny that internet goes fine, other MT winbox connection was fine, but only local has a problems, which also occurred sporadically.
I have the same issue as described here and I am struggling to find a solution.
I have a remote location that is routed through L2TP/IPSec Mikrotik-Mikrotik tunnel.
All data seems to be working fine but just the Winbox connection has the issue where it connects but with all the configuration empty and then in a minute or so it disconnects and then automatically reconnects and so on in a loop.
The actual MTU on L2TP tunnel is 1450 and network adapter on the local PC also has the Jumbo frame disabled.
I would appreciate any further opinions on what could be causing this issue.
I am still struggling with this issue.
In my case, I am using L2TP/IPsec tunnel between two Miktotiks and when trying to connect to a remote MT I can establish a connection but everything is empty.
In the meantime I have tried changing max MTU on server and on client side, disabling the “Change TCP MSS”, adding additional firewall Mangle rules to change the MSS (as describer here https://mum.mikrotik.com/presentations/MY19/presentation_7008_1560543676.pdf) on the traffic from/to the tunnel but nothing worked, no change at all…
Any new on this? i have now got the same error. I am using l2tp and eoip with trunk in it. I can connect to my routers no problems but all other behind the router i just get an emty winbox?
first i had the problems with all my LTE routere but then i upgrate to V7.6 and it go away if i join over mac adress. If i join over IP then winbox are emty? again on router no problems.
I have same problems on all 4011 i use as vpn client? all user trafic and all that is working with no problems, and ping in my dude is also ok. I think this has startet from v. 6.48X?
