In winbox click on telnet and you will see a ssh option, this will allow you to ssh to your remote router. It would be nice to be able to change the ssh port in that option.
I normally use putty, but I will rephrase my comment. For those who are gui orientated, it might be nice if they could put the port they wish to connect to in the ssh option in winbox
good point…but then by that definition there is no need for the telnet/ssh function (shortcut) in winbox.
I think in reflection Todd is really after a remote winbox as put forward in another thread.
Yes..
Often you can get a connection from within the router, but not from the PC you have connected to the router. It would be nice to have a relay of sorts so that winbox can connect to a remote router by accessing the immediate routers ssh and not a direct from PC ssh.
this would be extremly usefull… none of our CPE units have a routable IP address (it only provides local access to the tower for auto-upgrade purposes). we winbox into the tower and telnet into the customers’s CPE if we ever need to check something. the ability to proxy the winbox session would be very handy, as many issues could be handled by our level 1 staff if we had a simple to use gui for them to look at on the CPE side (command line is a little too much for some of the guys)…
Loads of ways around it already , if your CPEs have a web interface ,
SSH into the tower instead of winboxing , and just forward port 80 over it , then your staff can just put " localhost " in the webrowser .
If your CPE are Mikrotik boxes, just forward port 8291 over the tunnel as well , then you will have winbox and access to the graphs etc.
