Searching some around for the problem, but dont find any realy good answer in the forum to the winbox message:could not get index:missing file!
Winbox gets it’s files from your router, so if there is some file corruption, this message could appear. you can try to reinstall RotuerOS with Netinstall and see if it fixes the problem.
