Winbox error
Hi
I have a problem when I try to login to rB532 ver 2.9.23 with winbok
I get a error message
Bad file format ???
winbox is ver 2.2.7 have try with 2.2.10
hope someone have the rigth answer :smiley:
If you are connecting to IP Address, should not be any problem.
But if you do mac-connection, I prefer to use only one interface on laptop (or PC), and disable other interfaces.
But there is a problem, whith connection
and I use ip adresse
Problem solve
new upgrade
