Winbox.exe :: Pass Session As Argument
We use the following command/arguments to connect to a RouterBoard with Winbox directly from a URL (IE: IP address listed in CRM) or from theDude (IE: Custom Tool).
Dude Tool:
 C:\directory\winbox.exe [Device.FirstAddress] user pass
Chrome Extension: (https://add0n.com/external-application-button.html)
C:\directory\winbox.exe [HOSTNAME] user pass
Is there a way to pass the Winbox Session as an argument?
This would be super helpful to pull up the same Session every instance instead of creating one for each and every device that’s accessed.
Note: I’m aware of the risks by using these methods to store credentials. No need for scrutiny in that department, thanks in advance for your consideration.
