Winbox Feature Req: Show Winbox Bandwidth usage at top
Ie, at the top (where you can right click to add CPU usage/mem usage, Time and Uptime,) allow us to show the current bandwidth utilization of the winbox session.
I know the Green Bars in the top right corner show if data is being sent across the winbox connection, but we really need to be able to see how much bandwidth our current winbox session is using (without having to fire up Torch, and thus use even more bandwidth across the session).
when you start opening up several live updated winbox windows, the bw usage can certainly increase quite a bit (as is to be expected) but it would be very helpful to be able to easily see this usage (especially for winbox usage on upstream constrained connections or links)
Thanks!
+1
Also add dark theme to winbox.
Sent from my C6833 using Tapatalk
It is a good collocation, because it is be very useful
any plans to add this MT? winbox usage can easily get up into the 500k/s -1mbit range on large address-lists, dns cache, queue lists… users can forget and leave these open overtime and then wonder why their speeds at a site are taking a hit.
even winbox with interface list can often use 100k/s
thanks
+1 :slight_smile:
+1 :slight_smile:
