Winbox feature request
In Winbox, Registration list in Wireless Tables with right click you get pull down menu with options like Copy to Access List, Copy to Connect List, Ping, Mac Ping, Telnet, Mac Telnet and Torch.
Is it possible to also have an option like ¨Open with Winbox¨?
This way you can easily select a MT-device, right click on it to open and open a winbox session to that router! (Off course only in case MT router).
It saves looking up the IP of that unit, open Winbox Loader, fill the IP and open the unit.
rgds.
Exactly what you are looking for is available in Dude. Once you add your devices to be monitored into Dude, you can even view all wireless registrations across all Dude devices, on one screen! From there you can right-click and open in Winbox.
