Winbox Font Size
How you dare to discuss something with Mikrotik devs??? Everything they do is perfect!! /s
Stop this shitshow please, Mikrotik is going down the sink hole
I found a solution for this. Execute wine regedit.exe
Browse to HKEY_CURRENT_CONFIG \ Software \ Fonts
Double click LogPixels
Change to Decimal
Increase from 96 to 128, 144 (or larger)
In another terminal, execute wine winbox.exe
The fonts should be bigger
If the menu fonts are small, execute gedit ~/.wine/drive_c/windows/win.ini
Search the [Desktop] section (or add, if it doesn’t exist) an add or modify the line with the desired font size in pixels
MenuFontSize = 18
@secret, Your Wine reg tweak was very helpful.
Thanks !
@normis:
Is it possible to increase font sizc in winbox, the existing 5 levels of zoom in /settins/zoom are not enough on a hi-dpi display - the fonts are still too small on a hiDpi display.
Thanks!
I agree. Font size is a problem. Also winbox does not respond to scaling changes (windows display settings, scaling) like a standard application.
New WinBox around the corner. I guess the current WinBox won’t see/get a fix.
No need to guess, their support already says that they won’t fix anything in WinBox 3, if it’s not “critical”.
New WinBox in a beta and not even ready yet, many people don’t even like it. But they already dropped support of v3. It’s craziness… I don’t have any decent words to describe this.
The code in Winbox3 is so old, that it is impossible to fix a lot of issues in there. It’s the biggest reason why Winbox4 exists, so we can start improving it. We did not make Winbox4 just to annoy you with new color schemes.
