winbox for 2.9 ?
In winbox missing some command:
add firewall chain
add new routing tables
if there is another way to do this , how ?
everything works :slight_smile:
to add chain, push to “plus” (add) button and write whatever chain your need.
than you will see new created chain
  1. explaind what exactly does not work ?
you can create rules with routing-marks, and than routing-mark in ip route.
  1. yes , thx
  2. one routing table for ISP-1 , another for ISP-2 , and easy way is tables , with tables I do not mark traffic in mangle.
2.8 in route list have: Rutes , Tables , Rules , in Rules make :
x.x.x.x/x tables ISP-1
y.y.y.y/x tables ISP-2
not with any mark traffic , very easy to make, and have Action:lookup ,unreachable , drop
2.8 have also Flow for mark traffic with mangle , and Tables.
Look like Table is missing in 2.9 ? , …
because that , I ask , is the Tables put somewhere else … or only way is Routing Mark ?
hm, you setup routing-marks in mangle and gateways considering to marks in “ip route”.
more information:
http://www.mikrotik.com/docs/ros/2.9/ip/route.content#8.48.3.2
