Winbox for android, when?
Hello Team, someday will have the version of WinBox as the windows so that mobile for android? :smiley:
You can already use Webfig on any mobile device. Simply open the IP address of the router in your browser. in RouterOS v6 the functionality is identical to Winbox. We don’t plan to make mobile apps.
yes I already use webfig, so that many use version 5.22 for example, which has no webfig, some prefer not to upgrade to this version RCs because of probable bugs, in my opinion would be of good use for WinBox android OSs for less than 6.0 .
v5.22 also has the same webfig. the only difference is the icons
This app works very well :slight_smile: i’m using it on my Samsung I9000 (SlimBean ROM)
Winbox for Android Free
Webfig is “heavy” for phones.
Please port Winbox and also The Dude to android.
In what way is Webfig heavy for phones? It uses minimal traffic, and has nearly no graphics. Please clarify what you meant.
Yes, winbox for Android and Ios devices would be great! Much more pleasant to work in a familiar interface.
I own a 10 inch Win8 Atom based Tablet now. Just runs winbox natively and works
fine with an USB-Ethernetadapter.
I guess this is the smartest Solution.
Sorry but it is still not clear how Webfig is different from Winbox, if we are talking about Android. The only real difference is MAC connecivity, and that doesn’t apply to phones anyway. So you already have Winbox for Android
The main difference in safety, I have completely closed for 80 port to device. Allowed only winbox connection . To use webfig, I need to keep port 80 open. This is not acceptable.
You can change the Web access port to something else. You can also use HTTPS for managing the router, then disable port 80 and leave only 443 (or any other port which you will assign the SSL service)
@masyanich
its just that easy..
changing the port number will save me from bruteforce of admin password ? I do not think so ..
Proper firewall will save you from bruteforce..
Real differences:
MAC Telnet
Save passwords and IPs…
Access port is not a comum web port (you can change)
You can also change the Webfig port, plus Webfig is more secure because supports SSL
To the contrary :smiley: winbox is more secure because it supports TLS.
come on seriously you have no idea what the difference is?
tikbox and winbox are pretty similar as far as usability goes, if you dont understand then just trust us, its DIFFERENT
thats like putting on a maxipad onto a wound, it does the same but dont mean its better
or saying lets remove winbox now, http does the same except mac telnet <--------- mikrotik your best attribute is your Winbox client… you must know this!!!
So, to be clear, you can’t explain what is different, you just feel that way, correct?
